Hello; I want to open a door between Akuvox R20A intercom and HC3 with https command, can you help?
hello,
You have to write the scene:
function urlencode(str)
  if (str) then
    str = string.gsub (str, "\n", "\r\n")
    str = string.gsub (str, "([^%w %-%_%.%~])", function (c) return string.format ("%%%02X", string.byte(c)) end)
    str = string.gsub (str, " ", "+")
  return str
local AkuURL = 'http://<r20a ip adress>/fcgi/do' .. urlencode('?action=OpenDoor&UserName=<userName>&Password=<password>&DoorNum=1');
local selfhttp = net.HTTPClient({timeout=2000});
selfhttp:request( AkuURL,
    options = {method = 'GET'}
Edited by Olgierd
  • 1 year later...
 can you please update whether you managed to get it to work or not.
