That's sounds very weird and maybe I'm wrong, but if Lua code of virtual devices crashes ? - HC2 unable to remove device!?
Since there is no indication about virtual device code crash, user is unaware about it. It took me few hours to find why I'm unable to remove the device.
Anyone else has problems to remove the devices?
I had once and with Swapper removed it was gone.
Perhaps??
//Sjakie
  • 3 years later...
Guest Theo
As test I wanted to remove a device in HC2 but using the "X" does not work. Also the procedure to remove devices from the z-wave network appears to do nothing. Also the procedure "Add device" is unresponsive.
Any suggestions?
Edited by Theo
Sometimes a restart will help.
  • 3 weeks later...
Just removed two Fibaro plugs with X from my HC2 without problem, since were somehow disconnected from my HC2.
NOTE that with Firefox browser adding or removing devices does not work because of some security that does not allow popup window to show.
I'm using Safari to do actions with devices when needed since this works OK.
I really do not know why this two plugs get disconnected from my HC2. After resetting both plugs I manage without problems to add them to my HC3.
