Tomas Cech 0
I have Fibaro Smart Implant (used with Fibaro HC3) powered by 12V, with voltage connected to IN2 (need it for measuring solar power plant battery voltage). I simulate voltage input by a DC voltage source with changeable voltage.
However, the voltage is reported by the SmartImplant onlyafter I manually push "Reconfigure Device". Oddly enough, both MultiLevel Sensors of the Smart Implant are switched to "Not Used", yet correct voltage is displayed.
Once I change the voltage of the source, however, no change is reported, unless I again push the "Reconfigure Device" button again.
Parameters are set to 0.1V and 60s, but it does not matter. No change if I switch the MultiLevel Sensor to either "Analog Input (with pull-up)" or "Analog Input (w/o pull-up)".
Once again, once I push "Reconfigure device", the voltage reported is the correct voltage on IN2, so the sensor works fine; I just have no idea how I can force the Smart Implant to refresh MultiLevel Sensors.
Thanks for any clue in advance!
4 answers to this question
