Herni 3
Hi Everybody,
I have a problem. I´m trying to measure the difference time between the change state of the S1 channel of a double switch.
Therefore, in my scene is using the hub.get () command to extract "lastmodificationtime" of the value of the channel (see the picture below):
/monthly_2022_07/image.png.77bd4874ca813d326643c0acb802d17d.png" />After to extract the "lasttime1" value i compare the os.time() value with "lasttime1" value (to compare the time from high state to low state) (see picture below)
The problem is the if(tonumber(os.time() - lasttime1) sentence. I´m not sure if the problem is the data type used or not. But i can´t do that the if(tonumber(os.time() - lasttime1) sentence ejecute correctly. Could anybody help me? Thanks in advance. Best regard.
Hernán
6 answers to this question
