Is it possible to actually exlude a relay without using the B switch?
PilotPyles
Hi there,
I have the following enclosure around my Fibaro and I'm struggling to get it moved from SmartThings to HomeAssistant. I've hooked up a button from L to S1, and have repeatedly tried to remove it using a 3-press when in exclusion mode. Every time, however, I get a message that there are no devices to be removed.
Do I *need* to do a reset? Is this possible without taking the enclosure off?
I have these DIN enclosures too and know it can be a pain to remove the covers when they are all up against each other. However sometimes certain devices can be stubborn and a triple pressing of the B button is needed.
