JelleO 0
I just got the PSK01 keypad from Philio.
I can make block scenes and use any "key" as a trigger. i.e. when you press 1 or hold 1 or press 3 etc...
If I want to use a pincode as a trigger, I have to use magic scenes. Which is of course limited. Only in the "magic scenes" menu I get the option of using a pin. In block scenes this is impossible.
To work around this I could use a variable but they are not accepted in Magic Scenes.
Is there a way to use a variable in a magic scene or do i have to make a virtual device? Or is there any other way to work around this?
I just want: if pin code = correct, then start scene A, B or C
Any help would be appreciated!
