Fibaro HC2 activate Plug over API Control from EcoFlow Delta Max
Guest pblacky
My photovoltaic project is going into the test phase!
Already received and installed my EcoFlow Delta Max 2000 and first EET panel.
In the first tests it works quite well!
Now I'm working on loading the excess PV into the EcoFlow and using as little electricity as possible from the grid.
Unfortunately, I have to “load” something at night and had the EcoFlow API codes sent to me for this.
Now I have the challenge of finding out the battery level via the API control and activating a Fibaro plug with my HC2 as soon as the charge of the EcoFlow is below 20%.
Does anyone of you have experience with something like this and can help me get over the entry hurdle??
  • 4 months later...
Hi. Did anybody implement integration of HC2 and EcoFlow ?
