Perhaps a simple question: what is the USB port on the HC3 for.
I can't find an explanation about that anywhere.
Can I, for example, store snapshots on it via a memory stick?
Thank you.
Fibaro service only -> Corrupt OS restore, restore system from System C (in HC3 there is system A & B) and that kind of stuff.
as jakub said, system C, it was described in product presentation (boot from A / B or C)
As of today, Fibaro does not provided the "emergency flash drive" to certified installers, probably that will never happen due to security thoughts.
no, you can't, access to USB is restricted to system itself, and as user you have no system access
    All of you, thanks !!!
    Sometimes as a novice it is difficult to find the trees in the forest.
