Hi…
Just made a new Quick App with my own lua script (copy from a working quick app)
now when i call it i get this error: Child with id: 601 not found
I don’t have any child’s
Can any one help?
Br Sagi
    Here you go :-)
    Edited by Sagittarius
    Did you copy the code from another quickapp (or installed a fqa file) with child devices and later deleted the childs?
    I tryed both, and get same error…
    With no childs, never used it
    If there were childs in the original quickapp, that could be an issue. Have you already tried to add a new blanc quickapp and paste this code?
    Yes, its the one i just copy from… i tryed a -binary switch- and -Generic device- not sure what is best
    The fist time I call the Quick App, its working, next call give me the error…. Even when i try to click on/off
    can something in my code make a child?
    3 hours ago, Sagittarius said:
    Hi…
    Can any one help?
    Br Sagi
    Your problem is this line
    self.id is the QuickApp id of your QA and is vital for a lot of functions to work.
    Every fibaro.call to the QA will show an error because it looks at the deviceId in the fibaro.call(deviceId,...) and if it's the same as the QA's self.id it will call the lua function, otherwise it assumes that the call is for a child of the QA, but in your case it won't find any child with that id and complain that it couldn't find the child.
    In general you need to be careful when storing values in self.* as it may overwrite sensitive variables used by the QA...
    Thank you so much
    So its best not to use self. at all?
    11 minutes ago, Sagittarius said:
    Thank you so much
    Well, be careful. Because Fibaro has not documented all keys they have assigned to the QuickApp class, it's a potential minefield to assign your own keys to self. (We know from documentation some of them like self.id, self.name...)
    For a QuickApp without children I prefer to have local variables in the head of the file.
    If you have QuickAppChild objects it's nice to store child specific values in the Child class object for scoping purpose, so choose some non obvious names....
    Ahhh thank you
    i make them local instead then :-)
    • 2 months later...
    Thank you so much
    Edited by khurranakabeta
    same error…
    Edited by thikhh
