EuLink gateway - Fibaro
Hi
Do you have experience with euLINK Gateway from Eutonomy?
 I would like to connect Fibaro HC3 trough euLink gateway - RS485 to a ventilation unit Combi 302 Polar by Nilan.
For the Nilan Ventilation - i build a very cheap homemade RS485 controller, and you find a 99% working QA here
Also Nilan is implementing Local MQTT in their gateway
 this year, that should be pretty easy to implement.
So i would not select the euLINK Gateway for the Nilan
    Thanks!
    I'll try this.
