Geofencing works fine when leaving a location but delayed when returning
I use HC2 and android phone. Geofencing seems to work ok. Scene do start when I leave home location. Strange thing however is that when returning to home location it takes up to two hours before the scene starts. So HC2 does detect I am within range but only activate the scene two hours later. What could be wrong? Thanks for your help.
@EPAFIB
There may be a problem with your own phone/Android. Sometimes the location service "sleeps". Try roro: when you arrive in front of the house, open the maps and thus force a location update (your point must be in the real position on the map). Maybe then I will react to the scenes with Fibaro. Please let me know how you got on.
I have a Bluetooth location chip and all the work goes to waste if I don't use position accuracy. I will keep my current position at work with that chip, despite the fact that I am ahead of the som. Phone problem.
eM.
I am having geofencing issue for years. Apparently it will not be solved, as this is not a priority to any developer i think.
At this moment, my Coming home scene triggers only when i am inside my home like 3-4 minutes. Never on geofencing cross.
Sometimes i can see some notification that "YUBII is using your location", and it happens right at the places where the geofencing actualy is defined, but the scene never triggers. Only when i am inside my house.
