Tomasz K. 1
Hello All!
I have a problem with connecting the Everpring SP103 motion sensor.
Despite putting it in the mode of connecting to the Z-Wave controller (I press the Tamper button), the device is not detected by the HC3.
My configuration is: HC3 as master and HC3L as slave.
SP103 is to be connected to HC3L.
Do you have any idea what I can do to use it?
If you do not have a solution to the above problem, can you recommend some external Z-Wave motion sensors?
Normally I would use Philips Hue but it will not work with HC3L.
