We have 136 in the park, in version 4.620 we had a problem with going offline in the cloud. After the update to 4630 this was resolved.
After this update to version 4.630, some HCL stopped executing the scenes, being necessary to return the automatic backup made in the update (4620 > 4630), then it works again.
The client is about to open a 6-star maternity hospital, and the system is not working properly.
Right now we have 12 HCLS stops out of 136.
  • 4 weeks later...
 I have the same problem.
  • 2 months later...
Alguna forma de resolver este problema a mi también me han dejado de funcionar las escenas en el HCl
  • 1 month later...
    I have a good news.
    I talked with Fibaro and resolved this problem.
    You need create a virtual device to erase the notifications and delete the energy log, and make a scene to run this automaticaly.
    This three things will make the HCL wokrs fine, i dont know if this will work for you, but try there.
    Edited by Thiago Muniz
    Deletar Notificação
    DELETE /api/notificationCenter HTTP/1.1
    Host:
    Authorization: Basic
    MThhYjg5YTIxxxxxxxxxxxxxxxxxxxxxxMjAyQGdtYWlsLmNvbToxMjNCcmF2aXNOQ
    A==
    Content-Length: 11
    {"args":[]}
    Deletar Log Energia
    POST /api/energy/clear HTTP/1.1
    Host:
    MThhYjg5YTI3NTM3Mxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    Content-Length: 11
    • 10 months later...
    Inspired by Tiago Muniz above, I first clicked "Reset Energy Data", then clicked "Restart" in "General" in "Configuration". Then my scenes worked again!
    Memory full I suppose, unfortunately I did not check this first in "Diagnostics". Now I have 5% free space
