RobLu 0
I would like to share with you the solution below.
Z-TRM3 firmware 4.0
HC3 version 5.110.15
I have created a scene where the HeatIt TRM-3 should adjust the temperature for a set time.
Unfortunately nothing happens when a scene is created, see screenshot.
From the Quickapp it does work fine.
After some research with Swagger and ZeroBrandeStudio it show me that the wrong action is called from the scene.
Namely:
instead of:
In summary, the Lua below can be used to temporarily adjust the temperature and schedule. The argument string is also a bit different.
My device id = 43. This sets the temperature to 11.5 degrees during a period of 25 minutes.
I have passed this to HeatIt support, hopefully they will come up with an update.
