When i use
   local HT = json.decode(fibaro.getGlobalVariable("HomeTable"))
in a QuickApp, i get the following error:
[21.08.2022] [18:31:41] [DEBUG] [QUICKAPP24]: /usr/share/lua/5.3/json/util.lua:55: bad argument #1 to 'for iterator' (table expected, got number)[21.08.2022] [18:31:41] [ERROR] [QUICKAPP24]: QuickApp crashed[21.08.2022] [18:31:41] [ERROR] [QUICKAPP24]: Unknown error occurred: handleJsonRpc
In a scene this is no problem.
When i change it to:
   local jHT = fibaro.getGlobalVariable("HomeTable")
   local HT  = json.decode(HT)
then all goes well.
On my HC2 i use the nesting in both scenes and VD's
works.
fibaro.getGlobalVariable("HomeTable") returns 2 values. The value of the global and the modification time.
These two values are then sent to json.decode as two arguments. Unfortunately, json.decode accepts a second argument that are options for the decode, a table. However, modification time is a number so it fails when it tries to iterate over the table with options...
A simple way to convert 2 return values to one return value in Lua is to put parentheses around the call, like (fibaro.getGlobalVariable("HomeTable"))
So,
works.
    Thanks, i keep learning.
    Still strange that the same function fibaro.getGlobalVariable when used in a scene returns only one value.
    Yes, for some reason Fibaro has different implementations for the fibaro.* functions when it comes to scenes and QAs. The scene version don't return the modification time...
