Justino 3
I installed two “Fibaro Dimmer 2” and installed them as light switches with a bypass 2 as load and two momentary switch to S1 and S2. the S1 and S2 are associated to other Dimmer’s with lights attached to them.
So everything works, the only odd thing is. I have to hold the down the momentary switch for 2 seconds before a “signal” goes, and the light activates. When directly operating the Dimmer with the light attached to it, it works fine. And when using a scene there is also a no delay.
Any body a idea? Thank you in advance!
