the code below returns a code 500 response when run in ZeroBrane; on HC3, it simply crashes. I suspect it's a timeout issue, the server can take between 5 and 12 seconds to respond. How can I increase the timeout to say 15 seconds?
Output on ZeroBrane suggests timeout after two seconds
Two example respone time measurements
Thanks for your suggestions!
    Fixed, found a way to speed up the server. Would stil be interested to know if the timeout in request() can be increased.
    Like this:
    1
    2
    3
    function QuickApp:onInit()
        self.http = net.HTTPClient({timeout=3000})
    Well, 500 is "internal server error", and can be whatever. So, the 500 code is returned from the server.
    If the http request doesn't don't get a response within x seconds the http code will return the 'timeout' (because the server didn't answer).
    The default timeout is more than 2s, so I suspect there is something else going on...
    Thanks both for your answers
    Well yes, the timeout is just a theory. It's just strange that curl works and the lua function doesn't. And I never sae curl coming back with a 500 error.
    Anyway I changed the server logic to make it respond more quickly (by polling the value separately), and now it is miraculously solved. But I agree: I don't think I understood yet what was going on in the first place.
