Hi
I need to add manually some parameters for a device (Qubino Flush) due to lack of a template but i can't find where to do that?   I installed all my devices in V3
br//PAW
Device settings, Add parameter.
    Thanks but I'am missing add parameters in qubino this is what I have on my screen.
    The first picture is the child device
    Second picture is the parent device their is parameters greyed out.
    /monthly_2022_08/image.png.2fe18ef1d1d3e51a004c0ddb767feddd.png" />
    What Qubino is that? Maybe i can try it if i have it around. Looks weird anyhow.
    Download a template from another device where parameters have been noted.  Chnage it then to your liking, and upload it with the device  you like. If want to revert, just click on reset parameters.
    For now, it seems annoying, but I do see a good opportunity to share device parameters on a very easy way across this forum.
    The json I know share is for Zwave engine 3.0 Philio PSK1 (keypad) to set the parameter to Entry mode.  See JSON exmaple.
    • Like 3
    Momos:  I use
     it would be great if you have the time.
    Harthoofd:  I will try it out
    Thanks //PAW
