IS THERE ANYBODY WHO KNOWS IF ITS POSSIBLE TO ONLY PULL THE SPRING OF A TEDEE LOCK???
  • 3 weeks later...
LUA - hub.call(id'pullSpring')
Would like to see this as well.
The technical specifications of a smart lock may not seem applicable in real life. But in fact, this smart device changes everything in the way you use your door every day. A step-by-step explanation of the main features of Smart Lock will help you understand how all the technologies work together for your convenience It will help you use a smart lock in a way that is completely yours.
  • 3 weeks later...
There is a pretty comprehensive article on the manufacturer's website about the pull spring feature:
If you do not find the information you need, it is worth contacting their support. They respond very quickly and always try to help.
  • 6 months later...
    I found a way. Now Fibaro made it possible to do direct from the device options. but seems not to work correct
    The other way is to write a Lua script.
    local url = "https://api.tedee.com/api/v1.28/my/lock/LOCKIDHERE/operation/pull"
    local headers = {
            ["Accept"] = "application/json",
            ["authorization"] = 'personalkey HERETHEKEY',
    local selfhttp = net.HTTPClient({timeout=2000})
    selfhttp:request(url, {
      options={
        method = 'POST',
        headers = headers,
        data = json.encode(body),
        timeout = 5000
     success = function(response)
                print(response.status)
                print(response.data)
        end,
        error = function(message)
                print("error:", message)
    The only thing left is to make a personalkey on the website of Tedee. You can create an personal API key there.
    Edited by Nyko
