tnesheim 8
I have a Fibaro doorsensor (v2.5) where I use both the ordinary input(IN) and the tamper button(TMP) as inputs. The IN is quite simple, I connect to the terminal block. For the TMP I have done some solderwork, and this have worked fine for a very long time.
However, at some point(just identified the problem, but do not know for how log it has lasted) the TMP signal seems to be cancelled/reset by the state of the IN. This did not use to happen before, and the two inputs(IN and TMP) independently worked fine. Now they seem to be entangled somehow...in a way that renders the TMP-input not usable (the IN works fine).
I have looked at the datasheet
and apparently there are two ways the TMP works, throug associations and register settings. But, I'm not sure which "knobs to turn" to restore the old functionality?Link to comment
