Hello!
Does anyone know of a Z-wave rotary dimmer that will function in the US? (120v 60Hz, and 908.42 MHz)
Or is it possible to create one using a "dumb" dimmer with a z-wave relay that measures either impedance/resistance or volts, and then passes a dimming value to a smart dimmer module?
Thank you!
David Bailey
Utah, USA
Edited by David Bailey
spelling mistake
  • 4 weeks later...
You could try this with an Encoder and Z-uno. Check this
