knuth 28
I am writing a scene which needs to set the setpoint temperature of my Z-TRM2 thermostats using a LUA command in HC2. I plan to address each thermostat individually, not through heating panels.
The current value is succesfully retrieved by this command:
where id is the id for the setpoint sub-device of the thermostat. This works as expected.
However, when I try to change the setpoint through this command:
nothing happens, as shown by a subsequent getValue call. There is no error message, but the setpoint remains unchanged. I have tried to use the numeral 18 in stead of a string, and I have also tried with a variable name.What am I doing wrong in my fibaro:call command? The syntax is taken from the LUA API documentation, where this example is given:
Is the required command for the Z-TRM2 module different?
