loop through table
I have a variable with the following:
light{253,508,470}
curtains{250,80,36}
at the moment i have a script which controls the lights dependent on variables
how can i loop through the above table to get each light value and the corresponding curtain value?
4 answers to this question
    in my script i would like to have the list of the lights in a local variable so that i can switch them on or off
    when i have a simple table with just the device numbers,
    i did
    local GroupOnEndSecondGroup = json.decode(fibaro.getGlobalVariable("shabbosLightGroup"))
    which would give me the device list, however as my table has changed how do i list the lights in to a local?
    I am having problems in making the table too
    table.insert(tb,sld)
    just gives me a table with out any key value
    how do i make a table to reflect the above?
    {light{12,32},{c{523,532}}
    which would then allow me to iterate through the table to get the corresponding values?
    I dont reall understand your problem..
    What Eddy wrote, is the way you loop through a table..
    To find the coresponding value in curtain table, just use the key of Light table, while you looping
    or if you want to have everything in one variable, than use the same principle just check odd and even values...like use table {12,523,32,532} and every ODD number will be light, and every EVEN number will be curtain..this is what just came to me as the easiest way..
