HC2 Digest authentication for HIKVISION
I'm wondering if anyone else has managed to Digest Authenticate using HC2.
I found this useful link
but haven't managed to get the HC2 to successfully connect.
It correctly reads the 'WWW-Authenticate' challenge details
[DEBUG] 21:35:48: Digest HeaderWWW-Authenticate = Digest qop="auth", realm="DS-0AAC0497", nonce="NTZmMWY1MmEzNDY2N2FhODdhMWIwZTQ3NTRhY2ZhMWU=", stale="false", opaque="", domain="::"
and constructs a response and tries again with the corresponding header
[DEBUG] 21:35:49: HTTP Header: Authorization: Digest username="xxxx", realm="DS-0AAC0497", nonce="NTZmMWY1MmEzNDY2N2FhODdhMWIwZTQ3NTRhY2ZhMWU=", uri="/ISAPI/VideoIntercom/callStatus?format=json", qop=auth, nc=00000001, cnonce="63148d94", response="xxxxxxxx", opaque=""
bundle this together in what seems to be the correct header format
      local digestHeaders = {
       -- ["Content-Type"] = "application/json",
       -- ["accept"] = "*/*",
        ["Authorization"] = 'Digest username="'..username..'", '
                            .. 'realm="' .. params.realm .. '", '
                            .. 'nonce="' .. params.nonce .. '", '
                            .. 'uri="' .. path .. '", '
                            .. 'qop=auth, nc=00000001, '
                            .. 'cnonce="' .. cnonce .. '", '
                            .. 'response="' .. res .. '", '
                            .. 'opaque="' .. params.opaque .. '"' --, '
                            --.. 'algorithm=MD5'
      HttpRequest(method, url, data, digestHeaders, callback)
but the second HttpRequest fails to authenticate, it returns 401
Just to confirm
1) the HIKVISION unit is working fine I can happily connect to the HIKVISION door station from a terminal:
curl -v  --digest -u user:password  "http://x.x.x.x/ISAPI/VideoIntercom/callStatus?format=json"
or from Python using 'requests', so I know the HIKVISION unit is working.
2) I'm confident the Digest response generated by the LUA code in the implementation in the link above is correct, I confirmed this by overriding the Python requests method HTTPDigestAuth to allow me to specify the initial challenge and define the cnonce to match what I see in the initial challenge received by the HC2 LUA code.
Baffled from here and am wondering if there's a formatting, encoding, or other issue with the header I need to return.
I also had a look at the HC3 code provided by TInman here
the logic look similar to the HC2 equivalent in the url posted above and the header construction looks the same too.
Any help or pointers on this would be most appreciated.
there are some post for Hikvision availlable
