Auto off for output does not disable
I use Smart Implant for gate control on HC2 controller.
A push button with pulse contact triggers Input 1 on the Smart Implant ((Binary input NO, other binary input). This triggers a scene that closes Output 1 and sends a notification "gate opened". Output 1 is set to auto close with parameter 156 set to 1 sec. This works great. The gate opens and the gate controller closes the gate automatically after 20 sec.
Another push button with pulse contact triggers Input 2 ( (Binary input NO, other binary input). This triggers another scene that closes Output 1 to open the gate and the scene delayed opens Output 2 (parameter 155: Normally Closed) to block the gate controller. Also it sends a notification "gate opened and blocked". For this I need Output 2 to remain opened until told to do so. I set parameter 157 to "auto off disabled".  And indeed the gate opens, the notification is send and Output 2 opens. But Output 2 changes state back to ON after 1 sec.
My question is: How do I get the smart implant to maintain the postion of Output 2 Opened untl triggered otherwise? Or said differently: Why does "auto of disabled" not work?
Thanks for your ideas.
@EPAFIB
Change the "Local protection" parameter for the second input/output. Otherwise it is parameter 21.
Then you can edit the properties (input type) independently of the output.
