Nanoleaf integration from Santronic
JanRemco
Hi! I have used the nanoloaf canvas integration for the HC2 without problems for several years.
However, after migrating to a fritzbox I had to set up my network again, making sure everything had the same IP-addresses.
So I would think the nanoleaves still work, but no, not recognised. (i have two integrated in fibaro)
Now I am trying to implement them again by following instructions in the manual, (letting the leds flash on the nanoleaf then pressing the key symbol.) But after a lot of tries I have to give up, it wont work. Has anything changed? (Fibaro HC2 is on latest firmware as are my nanoleaves)
4 answers to this question
Do Nanoleaf lights works with their own app?
  • Yes they do work with their own app. However the Nanoleaf android app is very badly written, slow, and does not support their own thread models. So I try to use that as little as possible.
    Hi @JanRemco ,
    I use my Nanoleaf VD's with Aurora, Canvas, Shapes and latest with Lines without any problems. If you can provide some screenshots from main loop and from key (?) button I will be able to help.
  • In the end it was a mistype in the ip-address i did not notice. Everything is working, thanx!
