Damir Popovic 0
I have several Fibaro Roller Shutter's 2 on my HC3 Fibaro installation and they operate as expected. Recently I have installed three Fibaro Roller Shutter 3 on same HC3 and it seems that I am not able to use them.
They are wired the same way as Fibaro Shutter 2 (L and N wire are connected, S1 and S2 are connected to toggle switch on the wall). Q1 and Q2 are not connected to anything. That works on Roller Shutter 2.
When I press toggle switch on the wall, shutter operate normaly.
All Roller Shutters 3 are visible in Fibaro UI. When I press anything (Up or Down or Calibrate), I can hear "click" on device itself and in user interface it opens or closes. But Shutters do not move.
In Fibaro UI for each roller shutter 3 hardware I see parent device and 4 child devices. One of them is remote and other three look sa blinds with positioning. Which ever device I try to use nothing happens with shutters. With roller shutter 2 I have only one child device and it works as expected.
Any hints?
