Fibaro Aeon, 3 terminals, Z-Wave Plus (AEO-ZW0953C60A)
after updating and restarting this device the values froze and nothing is measured anymore, any advice ? I also did a reconfiguration and it still doesn't work. Thank you
Check if lifeline association is correctly set - we implemented official support for GEN2 Aeon Whole Home Energy Meters in 5.112 beta if I remember correctly.
Our piece works normally.
    The device does not automatically send the consumption data, I have to have a manual polling 125s. the device does not measure the production, the current shows positive for all, so it does not distinguish the direction of the current. could I ask you to set the parameters, what needs to be checked. thank you.
    • 4 months later...
    Dobrý den. Mohu Vám pomoci?  Umím s tím dělat v HC3.
