Powerfox Virtual Device - HTTPS GET
Qadyc
Hi all,
I was wandering if anyone has yet created a Virtual device for this?
It is a Energy meter with a good API, but I am unable to add it. can somebody create a virtual device for this?
This is the documentation regarding the API of the manufacturer:
There are documentations of adding this to Home Assitant or FHEM, but nothing well described for Fibaro.
The output would be { "Watt": 84.0, "Timestamp": 1566909358, "A_Plus": 276696.6, "A_Plus_HT": 193687.6, "A_Plus_NT": 83009.0, "A_Minus": 0.0, "Outdated ": false }
I´d like this to be a Energy meter Device so I can use it to switch on heavy loads in order to use my solar generated energy more efficiently.
Am using a HC2.
Thank you in advance
HI @Qadyc
just get the data a HTTP request and save the json in a global variable. Afterwards you can get the Data from the json and do what you want with it.
something like that:
