Do I tell something new?
Update done but hangs on restarting!
No problems here!
try unplug power and connect again if still is froze
    Thanks its running now after restart by unplug it
    Push in qa its not working
    It works fine for me.
    Both ways are working. One thing to know: the 'push' action is using userId as arguments and the 'simplePush' action is using mobile deviceId as arguments. You have to check what you're using. This works in the same way in lua scenes.
    But as I have seen in your other post, you're using some quick app/scene written by someone, yes?
    yes i can konfirm that user id is working   the mobil id is not working  yes the qa is made by Jang  Eventrunner 4
    @systemfel, try the code w.reys posted in your ER4 if that s working you should have probably an error in ER4 code.
    All Fibaro lua orders will also work in ER
    Maybe your mobileId has changed? Can you verify it?
    yes i have cheekd and its the same  ass before
    I reverted back to 5.11 due to second time HC3 restarted without any reason.
    Is it my recent modifications or ......
    Will stay 2 days on 5.11 if HC3  not restart it will be clear
