 Surprise after this update:
 All home panel icons are replaced with a "?".
 EXCEPT all other panels, which parts, or display is normal.
 Thank you for your help
fw from 5.11 >>>5.12 and Yubbi 1.16>>1.17 all icons visible in App .
Only some QA's with questionmark, I never selected an icon for them but als in HC3 so
make sure that you are in the same local network as you gateway.
Force close the app, next re-open the Yubii, app will download the custom icon automatically.
Regards
    Everything went back to normal (automatically) since my return to Poland (near my local LAN)Everything went back to normal (automatically) since my return to Poland (near my local LAN)
    Great - thanks for info.
    Sorry.
    The problem persists on certain icons, whether in the "OFF" or "ON" position.
    Really hopeless - With each update, new bugs appear.
    I am also looking for the possibility (finally?) of performing a geolocation that really works.
    It seems that Yubii Home Center offers this possibility - unless it is directly on the HC3?
    Same problem here. Both app and HC3 at the latest version. Some custom icons do not show, only question marks. Logout/login got most icons back, but only in one of two states - this happens with switches, shutters and door/window sensors. For example, a switch shows the right (custom) icon in one state, but in the other state it's a question mark. Is there a fix? Or do we need to wait for the next update that will probably create other problems that were not there before...
    The fix is waiting for next? update.
    Fibaro knows
