Dumperios 0
I am using 3 RGBW Fibaro Controllers 2. The first one is a little bit older than the others and it works fine.
The 2 newer ones have z-wave version 6.81.03 and device firmware 5.00. When I change the color or the brightness of the stribes, it takes over 5 seconds until the controller reacts for the first time and with each following change the reaction slows more and more down. For example I make 5 fast changes in my app it takes up to 1 or two minutes until the contoller reacts to the fifth change.
Do you know about this problem and ist there a bug fix for it?
Thank you.
