Marc_Zee 0
Hi All,
I am new to this forum and think I have a simple situation which should be obvious, but does not work as intended. I hope you can help. The setup runs at my parents, so I can't quickly verify things, but will try to get speedy results. Setup is running on HC2
Situation: They have a water pump which is intended to run between 7:00 and 8:15 every day when the timer is enabled. The setup consists of four block scenes:
1: Timer_on -> when run it turns a variable called timer_pomp to 1.
2: Timer_off -> likewise sets the variable to 0 and also turns off the pump
3: Auto pomp aan -> Intended to turn the pump on at 7:00 if variable timerpomp =1
4: Auto pomp uit -> Turns pump off at 8:15 (regardless of timer_pomp variable)
What happens however, is that the timer_on scene directly turns on the pump and not wait for the appropriate time to come. If expected this to be because the timer_pomp variable was set as trigger variable. I unchecked this box, but no difference. Any help is appreciated, please find the scence blocks below;
Auto pomp aan:
/monthly_2022_09/auto_pomp_aan_scene.png.74b5ea97618643c196d4b9abfdd2592c.png" />Auto pomp uit
Timer aan
Timer uit
Edited by Marc_Zee1 answer to this question
