MarioP 0
Somehow I can’t get the output of a SI to work.
What it should do
As a binary sensors (reed contact) is closed a relay needs to be engaged for 10 seconds.
Setup
Sensor is connected to blue and yellow wires of the SI
Relay is connected to OUT1
Parameter 20 is set to monostable
Parameter 156 is set to 10 seconds
Result
The switch does not react to the input (connect blue and yellow).
The switch can be set in the HC2 and resets after 10 seconds.
The output does not react at all.
If parameter 20 is set to “Binary input NO” it reacts to the input, however the output does nothing.
What do I do wrong?
7 answers to this question
