All my icons is gone  it workd in the prev version .now i see ? on my icons that i have made !!!
I asume in the Yubii app?
If yes log out and reload in should do the trick
Force close the application or log out then reload is not enough because some icons are still missing.
For instance binary switch, binary sensor, or multilevel switch... in fact, many devices that may have more then 1 state are affected.
The active icon is loaded in cache on first launch, but when device's state is changed, then the new icon is unknown : question mark "?".
You are right!.
My HA should work automatic without interference so I only check so now and than alarm panel.
If I open YubiiI se my added icons so I thought it should do the trick.
Thanks for your discovery.
