How to get number of days in the current month or last day of the current month
I'm trying to figure it out how to get the last day of the month in order to know if the current month has 28, 30 or 31 days but I was unable to and I couldn't find a solution in the forum.
Could someone point me in the right direction?
Thank you in advance.
I found something like this:
    It works great. Thank you.
    I was thinking if there's a function already implemented in Fibaro HC3.
    Cannot imaging that. Why do you want to know the maximum days?
    I need this in order to be able to project monthly usage of a power meter based on how much did it "use" till now as daily average.
    For example if today is 6th of September and the meter is 876 we know September has 30 days, so the projection would be 876/6 (daily avg) * 30 (days in current month). Perhaps is a better alternative for that,but I don't know yet. Also I need to do some processing on that data on last day of each month at 23h59m.
    This could be also used for energy consumption and/or solar panel production. Having better history would help me project better calculations in the future, especially for solar power production.
    Maybe using this function from Richard Warburton:
    It uses LUA built in functions and it support leap year, but year must be provided.
    Added time formatting as a bonus :-)
    Edited by Sankotronic
    Corrected code
    Wow. That's amazing! Tested and seems to be working - I'll do more tests in the upcoming days.
    Thank you.
    "{}" should be replaced with "()".
    Thanks and done.
