Hi
I reset some zigbee device before i remove the device from HC3
Now i am not able to delete the devices from HC3
Any suggestions
Thanks in advanced
Martin
  • 2 months later...
On my HC3 (5.130.64) have the same issue (no "force remove" option):
  • 3 weeks later...
I had the same problem and I checked serial number on the light and added to the HUE bridge ... using the HUE app using the serial number. Then it was automatically removed from the HC3.
Prior the light removal I also added new device through the Add Device > Other > Philips Hue ... and then it added the removed light to the HC3 devices automatically too. This way I can have the device in the HC3 as well as in the HUE gateway and use both. Which is for me more comfortable.
