Energy Panel - Battery energy and power configuration missing
I'm using the energy panel, and it's great. But I miss the configuration for battery power in hybrid PV systems. So then the performance of the billing meter doesn't match the reality.
The same situation applies to energy - battery energy is not calculated.
Two values are usually used for the energy of a battery - the charging energy and the discharging energy.
For power usually only one with a positive value for discharge and a negative value for charge.
Configuration - Battery power and energy is missing
/monthly_2022_10/image.png.dda431764269f5c873321b30e4336920.png" />
Energy Panel shows a meter power of 487W when in fact this power is used to charge the battery. The situation repeats itself in reverse when the battery power is used for self-consumption.
I'm also thinking to install a PV hybrid system for my home. I think Fibaro should address this battery issue in priority because it's critical for all people with a hybrid PV system.
    Yes, it would be very helpful to see the battery information: SOC state of charge, or charging and discharging performance.
    In my experience, the battery performance is in one value, it just differs in sign - charging is sometimes a minus, sometimes a plus.
    But the power is divided into two values, separately charging and discharging.
    The important thing is to be able to see a more detailed overview, but also a quick indication of whether there is enough energy or not.
    Some examples of PV system displays.
    I'd love to see something like this in Fibaro.
