The button to confirm the upgrade to 4.630 does not appear.
31 minutes ago, PJC_ said:
Appreciate the help.
You have to login locally.  Use the local ip-adress of the HC in you're browser, eventually use a privat tab or clear the browser cache.
    Thank you, entering through the IP solved the "problem" and it was possible to update.
