FIBARO integration with COMELIT alarm
MarcoOv
@MarcoOv
Hi, I don't know your Comelit alarm system. Check out the fibaro Smart Implant, it should do the trick.
The Smart Implant Manual is here:
@MarcoOv
Your question is very general. You don't write exactly what you want to control, in what way. Write to what type of safe system.
Generally, most of the secure system have the possibility to connect the so -called "Keyswitch".
It is an input that will be in the setting on the setting system to the ARM/Disarm.
Then you only connect to this entry.
Attention, some other resistors can be asked.
Note: The schemes, what did you get as a response, I only terminate how to "insert" a safety system detector into Fibaro and at the same time its status to signal in the original system. The question may not be related at all, ... but as I said, you wrote a question in general
