change color of light in lua
Jay Ess
i have a zigbee light on a hc3 and am trying to set the color of the light in lua, can anyone please advise me how i can do this please?
4 answers to this question
The check you do like:
Is not necessary and makes your code more complicated.
You use a variable rgbColor with string: "255,255,255". You now send this value to the first parameter of the  function fibaro.call() (or hub.call() in the new firmware), the other parameters are empty so nothing happens, try:
Try:
hub:call(deviceId, "setColor", red, green, blue)
If it’s a RGBW bulb: hub:call(deviceId, "setColor", red, green, blue, white)
deviceId is the id of the Zigbee device, red, green, and blue are integers from the RGB you like.
For example to set warm white: hub:call(22, "setColor", 239,235,216)
  • this is my scene:
    function TurnOnLights(GroupName,SetLightOnLevel,setColor)
        if SetLightOnLevel == nil then SetLightOnLevel = 100 end
        if rgbColor == nil then rgbColor = '255,255,255' end
        for k,i in ipairs(GroupName) do
            if fibaro.getType(i) == "com.fibaro.FGD212" then
                if fibaro.getValue(i, "value") ~= SetLightOnLevel then
                    fibaro.call(i, "setValue",SetLightOnLevel)
            elseif fibaro.getType(i) == "com.fibaro.multilevelSwitch" then
                if SetLightOnLevel == 99 then SetLightOnLevel = 100 end
                    fibaro.call(i, "turnOn")
                    fibaro.sleep(250)
            elseif fibaro.getType(i) == "com.fibaro.FGRGBW442CC" then
                    fibaro.call(i, "setColor",rgbColor)
                    --print(rgbColor)
                    fibaro.sleep(250)
            else
            --com.fibaro.colorController
                if fibaro.getValue(i, "state") == false then
    if fibaro.getValue(SwitchLeft, "value")==true then
        --TurnOnLights(GroupLeft)
        TurnOnLights(GroupLeft,25,'56,141,255')
    else
        TurnOffLights(GroupLeft)
    it sets the light to 25% but does not change the colour what am i doing wrong?
