Thank you for using our gateway! Be sure to update to the latest version to enjoy new features and improvements.
Main features:
1. Redesigned the way user access settings works
From now on, it is possible to grant access to devices and scenes by entire sections or rooms in the system.
Access to newly added devices and scenes will be automatically granted if an entire section or room is selected.
New user will automatically have access to the entire system from the beginning.
2. Scenes can be assigned to rooms
From now on, all types of scenes can be assigned to rooms, not just categories.
3. Z-Wave devices exclusion wizard
Z-Wave exclusion is now available in new wizard style.
Additionally there is an option to start exclusion directly from failed inclusion process.
What's new:
Devices
    Added Gateway filter to devices list.
    Added possibility to filter out power metering devices from mobile application energy panel.
    Changed UI for icons selection.
    Heatit ZM Single Relay 16A support.
    Heatit ZM Thermostat 16A support.
    Heatit Z-Push Wall Controller support.
    Heatit Leakage Stopper support.
Network
    Automatic selection of network connection type in FTI if only one is available.
Nice*
    Optimized support for OXIBD module.
Other
    Optimized trim of events database.
    Performance improvements.
    Added system notification about potential performance loss due overheating.
    Added possibility to clear all system notifications at once.
Profiles
Quick Apps
    Power sensor device type added to QuickApps.
    Removed password saving option in browser for secret variables.
Rooms
Scenes
    Added validation for time inputs in block scenes.
    Devices used in scenarios and hidden later are now shown on the devices list.
    Scenes name limit is changed to 60 characters.
Update
    Translations support for devices Update Service.**
    Devices update now available using remote access.
Z-Wave
    Performance improvements.**
Bug fixes:
Alarm
    Some alarm scenes are not listed in Alarm tab.
Climate Panel
    Some devices set to "Hold" in manual mode returns to schedule anyway after 7 days.
    Climate zone deactivation does not work for some device types.
Dashboard
    Favorite position label defined by user is not used on dashboard tiles and sidebar.
    Alarm status "dots" on sensors tiles does not change color according to current zone state.
    Scrolling long names does not always show the full text on device tiles.
Devices
    Issue with displaying current values of bit-mask type configuration parameters.
    Cannot navigate to child device using "parent-child" tree when filters are enabled.
    Newly added device is not visible when filters are set.
    After adding a camera, modal for adding "other devices" stays open.
    Wrong battery status for Sensative strip Guard 700 in some cases.
    Binary sensor cannot be used for Video Gate linked device.
    Missing possibility to sort devices using battery level.
    Minor fixes in UX for new devices filters.
    Missing support for some actions related with color control (fading, enhancing, stop color change).
Elero*
    Devices are marked as dead during binding procedure in rare cases.
Gateway Connection
    Incorrect role handling for FIBARO RGBW 1.
    Missing possibility to exclude device from slave gateway.
Nice*
    Redundant "Stop" button for gates on control dialog in mobile application.
    Removed redundant step in "pairing a remote in gateway" binding process.
Other
    Fixed Recovery UI issues in German language.
    Wrong display of "not used" RAM value in diagnostics.
    Not saved system language during FTI in some cases.
    Notifications creation time is calculated according to browser time, not system one.
    Mismatched translations when leaving Recovery mode.
Quick Apps
    Missing logs in console after page refresh.
    Quick App sprinkler device type is not supported in Garden Panel.
Scenes
    Unnecessary popup with "unsaved changes" in some cases for Scenarios.
Update
    Impossible to start second update for battery-operated device.**
    Last target in devices update stays in "In Progress" status even if whole process ended.**
Z-Wave
    Engine crash in some cases during multiple network management operations.**
Known issues:
Z-Wave Engine 3.0
    Some Z-Wave devices are not fully compatible with the new version of Z-Wave engine.
    Gateway connection is not available in the new Z-Wave engine version.
*  - does not apply to HC3L (Home Center 3 Lite)
** - applies only to Z-Wave Engine 3.0
  • Thanks 2
