Roobrother 0
I have purchased FGS-224 without reading the fine print and I was hoping someone can assist me.
The 24v ac motor is a HVAC damper ( open/close)
I was hoping to power the FGS-224 with say 240v ac pin L and Pin N
then connect the active of a 24v ac transformer to pin IN
S1 to 24v ac motor ( to close damper)
S2 to 24v ac motor ( to open damper)
The damper motor has three wires Com/open/closed
Do you believe this will work or will I need another external relay
Thank you in advance
JP
4 answers to this question
