zwmaster 0
Hi
i 'm using walli switch to trigger smart module or switch relay with no issue thru association done those thru controller.
- eg: physically pressing button 1 .....allows toggle remote of a light smart module relay no problem (ring led shows on /off accordingly)
now, When in the controller i have button S1 and Relay instances available -
issues are:
When toggling button instance ---> the e relay associated does not toggle (like it is when physically pressing button)
When toggling smart module / relay end points - i get might lights to swicth on/off naturally however walli switch and its ring led do not change
I 'm expecting to control lighting thru one instance (either relay end points or walli switch) yet the ring led not reflecting status is a big problem.
I have associated switch to relay in group 2 and even associated relay to button s1 but no luck
Any recommendation ? .
Thank you
