memory consumption increased by 50 percent to 93 percent, I went back to the previous version
Next time please download logs from the system.
We did not notice any increased memory usage.
Michał
Do believe that this is a visual thing only..
The meter to the left seem to have been “corrected”, now it shows the sum of used, buffer and cache memory.
the the previous version it only showed sum of Used and Buffer.
This is the view of my HC3 diagnostic after the update
The difference between used, buffer, cache and not used memory keeps people making wrong assumptions.
Mayby Fibaro should change the colors (now all kinds of blue) of the graph, to more distinguish the used, buffer and cache memory. Now it looks like there is only a few percentages “not used memory”, which is actually not the case if you also look at the cached and buffered memory.
