I'm asking the forum for support regarding the creation of software documentation in HC3.
(please answer yes/no)
I propose to create a button in the /app/settings/general/main location, which would make a documentation in the text format as similar as possible (included a graphical side) to the HC3 programming area in LUA scenes.
The file name should be DocFIBYYYYMMDDTime.LUA. It would be used for comparison with older versions of the software in Visual Studio Code (Microsoft).
I really
appreciate the HC3 system. However, my customers and I lack a documentation of all scenes in the text format in one file. This collection would allow me and my customers to rewiev the previous data to remind ourselves the original state of the software and settings. When our system doesn't work, I would like to find what I have changed before or what have gone wrong. By comparing the original documentation with the new one, I would have an immediate overview. Furthermore, this documentation could be useful to search for the ID numbers in the scenes.
As you probably know, sometimes we are forced to remove and add the ID again. This
causes the ID to be renumbered. As a result of it, it is necessary to replace the old ID numerical codes with the new ones in all scenes. When renumbering the ID of, for example a three-phase electricity meter, it has to make 32 times.
The structure of
the documentation is described in the "BLOCK Scheme" below.
An example of
the documentation is given in the "Example of documentation" below.
Experts may program in other languages and make extensive use of APIs, but the system is not intended for them, but for the general public. The public needs outputs perhaps more than experts.
I w
ould be grateful if FIBARO looked into this as soon as possible.
With thanks for your cooperation     ing. Petr Boltík
"BLOCK Scheme the documentation"
procedure CreateTXT(DocFIBYYYYMMDDTime.LUA);
var i,sceneMAX: Integer;
BlockScene: boolean;
begin
 for i := 1 to SceneMAX do --the main passage
 if exists(scene[i]) then
 begin
  if BlockScene then TraslateBlockToLUA;
  SaveNumber and NameScene;
  Save DECLARATIONS (Conditions/Triggers) scene;
  Save "---------------------------------";
  Save ACTIONS scene;
 end;
 for i := 1 to QuickUPMAX do --passage QuickUp
 if exists(QuickUP[i]) then
 begin
  SaveNumber and NameQuickUP;
  SaveDevice???
  SaveMain;
 end;
 for i := 1 to rowDocumentTXTMAX do --passage control on exist ID and SC
 begin
  if search ID (not exists in systém HC3) then
  begin
   changetxt "IDXXX" on IDXXXNotexists or IDXXXERROR
  end;
  if search Scene( not exists in systém HC3) then
  begin
   changetxt "SCXXX" on SCXXXNotexists or SCXXXERROR
  end;
 end;
 for i := 1 to IDMAX do --passage ADD params ID
 begin
  SaveNumber and NameID;
  Save name Params and value;
 end;
end;
"Example of documentation":
--SC46 on device >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
table = {
  isTrigger = true,
  operator = "match",
  property = "cron",
  type = "date",
  value = { "0", "*", "*", "*", "*", "*" }
local currentHod = os.date("*t").hour
hub.call(467NOTEXIST, "turnOff")
hub.call(468, "turnOff")
hub.call(469, "turnOff")
hub.call(470, "turnOff")
if (currentHod == 0) then
  --hub.call(470, "turnOn") --zahrada vzadu
elseif (currentHod == 1) then
  hub.call(467NOTEXIST, "turnOn")
elseif (currentHod == 2) then
  hub.call(469, "turnOn")
elseif (currentHod == 12) then
--SC47 off device >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
table = {
  isTrigger = true,
  operator = "match",
  property = "cron",
  type = "date",
--local currentHod = os.date("*t").hour
--SC48 on device >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
    Ticket ID: 226025
    Ticket: Petr Boltík
    _______________________________
    Thank you for the message!
    We appreciate your involvement in improving our systems.
    Thank you for the precise suggestions, I already redirected them to our RnD department :)
    Pozdrawiam/Kind regards,
    Kacper Klensporf
    Tech Support
    +48 618 801 000
    +44 845 154 2852
    +33 970 733 545
    is related
