Hi everyone
if i do so in 5.130.45 the HC3 run into an error and dosen‘t work. I have to restart the HC3.
Hello!
It is working on our side, this must be something specific on your system.
Please create a support ticket and we will take a look :)
Michał
try to check whether a variable in your scenes is having an incorrect variable - i somewhere noted in a scene a time, without entering the time itself, and saved it (that is or was a bug, should not be possible). However that caused my hc3 to be instable. After finding this issue, it al worked again.
