Hi, I’m having a bit of trouble. I’ve got some led strip lights on a 300w and some on 200w drivers. First start up in the mornings it takes 5-6 attempts to turn the lights on. I have an identical set up on 300w driver on the floor above and that has no problems. I’ve  spoken to nice uk about it and I’ve changed some of the parameters on the devices with no luck. I was then told to try a dimmer bypass resistor which made no difference. Has anyone had similar problems and solutions ?
thank you.
@Daz7h
Write what type of source you have. If you write about a "300w driver", I'm afraid you have an inadequate power supply.
Considering the two different loads, I don't know if you have both on each dimmer, or if you use each driver with your dimmer. The second option is correct. Try to specify your connection, your power sources/drivers.
Edited by Martin_N
    Sorry, all drivers are controlled by separate Fibaro dimmer 2 units. They are controlling 24v 300w led drivers.
