zwmaster 0
Walli button triggers both own relay and association, while Switch Binary Set from a controller will only affect the relay.
This is creating a management of multiple instance to keep in sync now required thru the controller while association is there to avoid it
Hence my questions :
Is this situation by design or am i missing configuration setup ?
As general how do you manage walli controlling lighting module so that user sees one light and Not a button+relay+separate module swicth
Thank you
