I have two new HC3.
At first start update is done to 130
Try to set static IP
Green pop up comes up: Successful
Go anywhere in the menu, then come back to network no static IP. The roll down is says: Choice (not static)
The solution was: roll back to original firmware, set static IP, then update and it is working.
Anyone with the same problem? This was 3 hours to get the solution.
The easiest way is to make an IP address reservation at the router in my opinion.
    Yes, but I have no access to the IP network at this customer.
